hydraulic fluid in oil?
   / hydraulic fluid in oil? #1
bob sullivant
topeka ks.
kkubota b7200 hst
I have a b7200 Kubota HST that is leaking more and more hydrauliic fluid and I can't locate the leak. Now the engine is blowing oil everywhere. The crankcase is quite overfull. I don't smell diesel in the oil so I suspect the hydraulic pump is leaking into the crankcase. I could use some advice.
   / hydraulic fluid in oil? #2
Sounds like you are right to me. You can replace the seal, but in my experience it will only be temporary, the best solution is likely to replace the pump.
Brian
Thanks for responding even if you didn't tell me what I wanted to hear. I visited the dealer today and learned a new pump is five hundred bucks. The parts man showed me an exploded view of the pump. Guess I will jerk the pump off and see what it looks like.
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
New/Unused Hydraulic Thumb for CFG Mini Excavator (A54865)
New/Unused...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
Year: 2018 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: (A55853)
Year: 2018 Make...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
