Buying Advice L3400 HST-F is this 4wd?
   / L3400 HST-F is this 4wd? #1
kootenai
Member
North Idaho
'07 Kubota L3400. Woods: Tiller, Back Blade, Box Blade, Backhoe
Hi Gang,
I found a low hour L3400. For the life of me (and I was a little road weary) I could not find the shifter for 2wd - 4wd. A cursory search on tractor data suggests that there is only 4wd with HST. Is this an "All time" 4 wd? Or what gives, am I blind? I have included the Model number in the photo to expedite an answer from those of you in the know......
   / L3400 HST-F is this 4wd? #2
I believe the Fs are 2wd with FST - full synchro tranny (manual),
the DTs are 4wd with FST,
the HSTs are 4wd.
If it's 4wd (DT), then there should be a lever, down low, to the left, just behind your left heel when you're sitting in the seat.
Down for dirt; up for asphalt.
For some reason, the Kubota website isn't showing the L3400 in the previous model listing ....
   / L3400 HST-F is this 4wd? #3
Unless the HST is different, mine is on the centerhump to the left a bit and tucked under the seat almost.
And on mine, its down for asphalt (2wd) and up for dirt (4wd)
   / L3400 HST-F is this 4wd? #4
x2, its an orange t-handle on my machine.
Well OK, thanks for not coming out and saying it, but I must be blind. I searched all over for that knob. I thought, that's a mighty nice tractor to NOT have 4wd. Glad I am wrong... Now, off to solicit input as to whether it is a good deal.
   / L3400 HST-F is this 4wd? #6
Also just look at the front axle, does it have final drive cases down low? (4wd)or is it a solid axle ? (2wd) on the right hand side upper side is fill port for oil for the axle?(4wd) Crawl under the engine, does the oil pan have a tunnel for the front driveshaft? (4wd) What do the front tires look like? Ribbed (2wd)
On the one I had, it was HST with 4wd, and had a T handle by your left heel to shift from 2wd to 4wd
James K0UA
   / L3400 HST-F is this 4wd? #7
No problem. there must be a secret society that designs the 4wd enagagement controls. I dont think I have ever been on two tractors that it was the same between them! Its even worse between seperate brands!
Found it!
I thought it was a seat adjustment, I had to have the seller take a picture and send it. DSCN2510.JPG
   / L3400 HST-F is this 4wd? #9
IT WAS CAMOUFLAGED!!! Organge blends in with orange nicely. If you try it out, don’t engage it while you’re moving, it’s not a synchronized gear set.
Haulmaster Quick Hitch (A50515)
Haulmaster Quick...
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2014 Ford Fusion (A50324)
2014 Ford Fusion...
