Pole Barn vs Steel building ASAP!!!!!
   / Pole Barn vs Steel building ASAP!!!!! #11
Sorry to learn of your misfortune.
If you are interested in a Quonset type building, my son knows a guy who may still have one that was never put up. If you are interested, let me know and I will see about it's size, cost and availabiltiy. It would need to be trucked from near Minneapolis, Mn.
   / Pole Barn vs Steel building ASAP!!!!! #12
46ford
- If you need some help with this give me a shout. I design these structures all day long, and can send you preliminary drawings.
Some of the comments here are helpful, but I woudl disagree on the foundation part. Steel buildings typically require a concrete foundation, but I have designed them in the past with wood piers, concrete sonnet tubes, or other minimal concrete requirements. It helps keep costs down. Give me a shout when you're free and I'll be happy to help you with this. 757-961-7009 Gary Parker - Project Manager - SteelMaster Buildings, Virginia Beach, VA.
   / Pole Barn vs Steel building ASAP!!!!! #13
   / Pole Barn vs Steel building ASAP!!!!! #14
I'm for the pole building. I'm biased though... I'm a logger, I will always build with wood:).
I have built two pole buildings, my neighbor built one of steel. Not much difference really. I do like the pole bldg. for hanging stuff, etc. I would spec. Doug fir for the wood if possible. I was surprised to see how many "kits" are built with hem/fir vs. Doug fir in our area.
Steve
   / Pole Barn vs Steel building ASAP!!!!! #15
Could you explain the reason you would specify Douglas fir? I do know it is much denser and heavier, does it hold up better over time?
   / Pole Barn vs Steel building ASAP!!!!! #16
You bet. White woods, Western Hemlock and true firs, are more brittle than Douglas Fir. In addition, they seem to be more prone to shake. My experience comes from cutting/felling these trees every day, professionally.
Most of the the "quality" builders around here, don't use hem/fir for building at all. That said, Douglas fir is widely available. It is our primary species of tree.
My comment regarding Douglas fir vs. hem-fir was that many kits that can be purchased locally spec. out hem-fir to save cost. I have spec'd my kits with Douglas fir for nearly the same cost.
Steve
   / Pole Barn vs Steel building ASAP!!!!! #17
It will be a couple of years before I can get serious about a building, but I will keep this information in mind. Thanks.
1270 (A50490)
1270 (A50490)
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
Loader Arm (A51691)
Loader Arm (A51691)
2008 Ford F-250 XL (A50120)
2008 Ford F-250 XL...
