Rebuild both cylinders at the same time?
   / Rebuild both cylinders at the same time? #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
While in the tractor shed the other day, I noticed that the right side boom cylinder on the 110 loader has got a pretty good leak started. Nice puddle there on the ground! Looked up the seal kit repair on www.JDParts.com and it's about ~$42.00. Whew... :)
So, my instinct is to rebuild both loader cylinders at the same time. I'm doing the work and it's a pretty cheap repair. But, the left side is dry - no problems. (If it ain't broke... don't fix it?!?) Nonetheless, my logic is that after rebuilding the right side the loader might have slightly unequal lifting capabilities and the older cylinder (~1,200-1,300hrs) will start to fail in short order.
Any thoughts or opinions?
Thanks.
AKfish
   / Rebuild both cylinders at the same time? #2
I would rebuild both. They each have the same wear, only one failed first.
   / Rebuild both cylinders at the same time? #3
It is a crapshoot. Nothing says the other one will or will not start leaking any tiime within the next 1000 hours of use. Do whatever makes you happy.
   / Rebuild both cylinders at the same time? #4
I would also rebuild both
   / Rebuild both cylinders at the same time? #5
Buy two kits and put one in...
   / Rebuild both cylinders at the same time? #6
I agree, UNLESS you cant have unexpected downtime from a leaking cylinder. The other one could die tomorrow, or it could be fine for 10 more years.
Aaron Z
   / Rebuild both cylinders at the same time? #7
I am in the "do both" camp, like headlights, wipers, brakes, tires, ect they both have the same wear on them. Only time I wouldn't is if there is obvious damage from an outside force on the side that's leaking.
   / Rebuild both cylinders at the same time? #8
Why is it that in my mind I would've done only one, until Kenny showed up? :confused: :thumbsup:
   / Rebuild both cylinders at the same time? #9
Rick
I agree with you. There's no telling how many hrs use the other cylinder will give before it fails. I'm in the "if it aint broke don't fix it" group.
   / Rebuild both cylinders at the same time? #10
Fix the one that leaks . I've seen this repairs go both ways . It is either fixed or leaks worse . The other cyl . may never leak , unless you open it up .
2023 Load Trailer (A55787)
2023 Load Trailer...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
More info coming soon! (A56859)
More info coming...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56436)
2022 Greenworks...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
