Rebuild both cylinders at the same time?
   / Rebuild both cylinders at the same time? #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
While in the tractor shed the other day, I noticed that the right side boom cylinder on the 110 loader has got a pretty good leak started. Nice puddle there on the ground! Looked up the seal kit repair on www.JDParts.com and it's about ~$42.00. Whew... :)
So, my instinct is to rebuild both loader cylinders at the same time. I'm doing the work and it's a pretty cheap repair. But, the left side is dry - no problems. (If it ain't broke... don't fix it?!?) Nonetheless, my logic is that after rebuilding the right side the loader might have slightly unequal lifting capabilities and the older cylinder (~1,200-1,300hrs) will start to fail in short order.
Any thoughts or opinions?
Thanks.
AKfish
   / Rebuild both cylinders at the same time? #2
I would rebuild both. They each have the same wear, only one failed first.
   / Rebuild both cylinders at the same time? #3
It is a crapshoot. Nothing says the other one will or will not start leaking any tiime within the next 1000 hours of use. Do whatever makes you happy.
   / Rebuild both cylinders at the same time? #4
I would also rebuild both
   / Rebuild both cylinders at the same time? #5
Buy two kits and put one in...
   / Rebuild both cylinders at the same time? #6
I agree, UNLESS you cant have unexpected downtime from a leaking cylinder. The other one could die tomorrow, or it could be fine for 10 more years.
Aaron Z
   / Rebuild both cylinders at the same time? #7
I am in the "do both" camp, like headlights, wipers, brakes, tires, ect they both have the same wear on them. Only time I wouldn't is if there is obvious damage from an outside force on the side that's leaking.
   / Rebuild both cylinders at the same time? #8
Why is it that in my mind I would've done only one, until Kenny showed up? :confused: :thumbsup:
   / Rebuild both cylinders at the same time? #9
Rick
I agree with you. There's no telling how many hrs use the other cylinder will give before it fails. I'm in the "if it aint broke don't fix it" group.
   / Rebuild both cylinders at the same time? #10
Fix the one that leaks . I've seen this repairs go both ways . It is either fixed or leaks worse . The other cyl . may never leak , unless you open it up .
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
New/Unused Agrotk Tire Changer (A57454)
New/Unused Agrotk...
2011 Peterbilt 365 Altec AC38-127S 5 Section 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Tr... (A56858)
2011 Peterbilt 365...
1993 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
1993 Ford F-250...
Skid Steer 59in Vibratory Roller (New/Unused) (A59225)
Skid Steer 59in...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
