TC35D PTO shaft question
   / TC35D PTO shaft question #1
LabLuvR
Gold Member
SC
Kubota MX5400
Is there a way to make the PTO shaft free turning? I've only had my tractor a short period of time and I want to hitch up a tiller. But, it seems like that will be a major hassle, if I can't get the PTO to turn by hand for alignment. Thanks guys!
   / TC35D PTO shaft question #2
Attach the tiller to the 3PH and lift it until the blades are off the ground. Turn the PTO shaft from the tiller so it mates to the PTO stub on your TC35D. The TC35D has a PTO brake that slows and stops the PTO very quickly as you disengage the lever. It cannot be moved. You have to rotate the implement shaft.
If you have the mid-PTO option, you can disengage the rear PTO so it will turn, but without the mid-PTO option, your PTO stub will not rotate. Some people have even installed an over-run clutch to defeat the brake, but that also makes a hazardous condition when you disengage the PTO with a rotary cutter and it keeps spinning. Your choice. . .
Thanks, I like the tractor a lot, but my Kubota shaft was free spinning. Much easier to hook up bushhogs etc.
I do not have a mid PTO, can I still install the over-run clutch? If so, will my bushhog yokes etc still fit like they are?
Thanks again!
   / TC35D PTO shaft question #4
The over-run clutch will add about 6" to your PTO stub length. More than likely, you will have to shorten the PTO shafts on your implements. That could end up being far more hassle than raising the implement enough to turn the PTO shaft. If you ever decide to go back to the non-clutch configuration, then you'll have a bunch of short shafts. I have a rotary cutter, tiller, post-hole digger, and chipper-shredder. That would be a lot of work for me.
Agreed, I will just stick with what I have. Thanks!!
2018 Ford F-550 Altec AT48S 48ft Material Handling Bucket Truck (A55973)
2018 Ford F-550...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
2025 Yakta YXR970 Zero Turn Mower (A57453)
2025 Yakta YXR970...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
