Need help with TSC middle buster plow top link pin diameter
   / Need help with TSC middle buster plow top link pin diameter #11
Sorry for the confusion. I have a normal Cat 1 top link and my box blade and tiller use standard Cat 1 top link pins so 3/4" in diameter.
The top link hole on the hole of the plow is 7/8" maybe more like 15/16".
Just let it rattle around with the standard 3/4" pin. It won't hurt anything and the tension on the business end will keep the pin fairly tight.
Another alternative is to ream out (drill or torch or plasma cut) the top mount and weld in a Cat 1 to Cat 2 bushing. I did that to modify some of my Cat 1 implements to Cat 2 (except a Cat 2 to Cat 3 bushing was used of course).
After you weld one side you can hacksaw off the extra bushing length and use it on the other side. Cost is less than $2 if my memory is working.
It is probably not worth the effort and using it as is will be fine.
   / Need help with TSC middle buster plow top link pin diameter #12
CountyLine must have manufactured the plow according to some incorrect specs. They claim it meets Cat 1 standards and they have the correct 7/8" lift pins but a top-link hole of somewhere between 7/8" and 15/16" is just plain wrong. It would take a pretty unusual bushing - two of them actually - to correct the situation.
   / Need help with TSC middle buster plow top link pin diameter #13
Yep, if it is indeed a 7/8" hole, that is incorrect.
Personally, I would just use as is. It would take years of use for it to waller out and become an issue. And being a little sloppy only makes it easier to hook up. And if you are really worried, do as others have suggested and use bushings.
You can either make a correct sized bushing, or make the hole the correct size for a catI-catII bushing.
   / Need help with TSC middle buster plow top link pin diameter #14
This problem is still not fixed. I just came back from TSC. I was going to buy a potato plow. The cat 1 pin went completely through the top link hole and a cat 2 pin would not fit into them. They had 5 of them. The sales associate told me he wouldn't buy one either. I drove an hour to go to the store. I am debating on driving to the other 2 stores that are an hour round trip as well.
   / Need help with TSC middle buster plow top link pin diameter #15
Yep, the top link holes on my big, yeller, TSC FarmFarce (CountyLine?, KK?) subsoiler are a bit oversized, but it still works fine, as-is. Here it is, wearing a tater blade:
   / Need help with TSC middle buster plow top link pin diameter #16
   / Need help with TSC middle buster plow top link pin diameter #17
Hitch pin with washers on each end through the middlebuster top link hole.
   / Need help with TSC middle buster plow top link pin diameter #18
That still won't fix the issue with the wrong sized hole. Either they meant to drill the tl hole a full 1/8" over, or this is a big mistake made by qc
   / Need help with TSC middle buster plow top link pin diameter #19
I have the diagram in front of me for the different size hitches and pin sizes. Top link for a category 1 is 3/4 inch, category 2 is 1 inch. If the lower link pins are 7/8 inch (correct for category 1 implements) and the toplink hole is bigger than 3/4 inch, I'd say someone at the factory is messing up. I'd take it back and get one with the proper holes or enough refund to remake that one into the right size. I don't like sloppy fitting pins and it would drive me crazy.
If they give enough refund to fix it you might could change one of the eyebolts on another top link to fit your current mis-matched holes. But then that top link would be good for that particular implement only. Not sure if the bolt sizes are the same for toplinks in the 2 different sizes...just a thought.
   / Need help with TSC middle buster plow top link pin diameter #20
Phillg, I can make quite a few phone calls in an hour and save a lot of gas too.
L2800 w/FEL - 72" Land Pride rake
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
McFarlane 4030 Reel Disk (A59814)
McFarlane 4030...
2022 CATERILLAR 303.5 CR EXCAVATOR (A60429)
2022 CATERILLAR...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
