jeff9366
Super Star Member
- Joined
 - Jan 14, 2011
- Messages
 - 12,787
- Tractor
 - Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Ford Series 101 Plow, 2-12  /  Interference Issue With Right Lifting Rod / 3-Pt.
Common Carrier delivered this Ford Series 101, 2-12 Turning Plow yesterday, purchased from excellent Sweet Tractors.
I got plow off the pallet yesterday evening. This morning I am adjusting plow to my Kubota B3300SU / 33-hp / 1,900 pounds / 4-WD.
Harry Ferguson and Henry Ford worked on the Ford 3-Pt. design and implements together. I though this plow would go right on the Kubota 3-Point. But there is an issue with the massive First Beam on the plow interfering with the right (turnbuckle) lifting rod.
When the Landing Lever is all the way to the rear, the first beam rubs the barrel of the adjusting rod.
When the Landing Lever is in center position there is 7/8" clearance. Not enough clearance when plow and tractor are moving semi-independently.
When the Landing Lever is forward there is 1-3/4" clearance.
(Stabilwork's pin adjustable stabilizers are pinned to hold plow just to left of center between tires.)
When I get the plow working in the field any obstruction in the ground will make the First Beam smack into the lifting rod with 650+ pounds of inertia, likely ruining the lifting rod.
The plow cross shaft is in its "normal" position, one hole showing on the right.
I will be plowing on flat ground, sandy-loam soil, minimal rocks and those soft limerick.
WHAT AM I MISSING? i know there is a secret.....
One solution would be to take the First Beam to the welding shop and have them bandsaw off 6" but I am reluctant to cut this completely stock "classic" plow.
Surely there must be some adjustment, or combination of adjustments, I am missing.....
I have never owned a plow, I have never adjusted a plow, I have never plowed. [ Wish I could post this line in LATIN but I got kicked out of Latin class after three days. She said I would be sorry. ]
Photo #2 Landing Lever to rear; First Beam interferes with right lifting rod.
Photo #3 + #4 Landing Lever in center; some clearance.
Photo #4 Landing Lever forward; 1-3/4" clearance.
Minutia: Why are there both HEX and SQUARE head bolts on this plow? Is there an advantage to square head bolts in some applications?
