/ Ford Series 101 Plow, 2-12 / Interference Issue With Right Lifting Road / 3-Pt.
jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,787
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Do the Stabilworks links interfere with mounting the Pats Easy Change? I wouldn't think so, since the standard PEC attaches to the hitch balls, IIRC.
With Stabilworks arms pinned open, it is easy to back up to implement draw pins, set the lower links to same level as draw pins, pull the Stabilworks pins, and push lower link eyes on draw pins.
Stabilwork's mechs would not be needed with the heavier class of 50+HP Utility Tractors, but for CUTS and the Kubota B series in particular, they are a wonderful addition adding strength in a weak area when PUSHING loads in reverse.
There are multiple threads here on T-B-N from owners of compact tractors, various brands, who bent lower links and/or lifting rods when PUSHING loads in reverse.
I have several PTO implements. I do not want to add shaft length adaptors if I can avoid it.
BACK TO MY FORD SERIES 101 PLOW.......PLEASE......
