Property line on19.5 acres
   / Property line on19.5 acres #1
Timm250
Gold Member
Western KY
Kubota M6800 w/1600 hrs., Case Farmall 95 w/800 hrs., Long 2510 w/1100 hrs, Cat 236B2 Skidsteer w/1000 hrs
There is 19.5 acres that joins my other property that is for sale. My property already joins this property on 3 sides. The plan is to buy this & fence the side that doesn't join my current land for cattle. The one side has a section that is 1700 ft long then turns at an angle & goes another 1000 ft. The property has been surveyed about 2 years ago & there are pins marking the corners. Is there an easy way to connect the corners without a surveyor so that I can put a fence on the property line? The land is rolling and the line I need to layout goes through the woods & thick brush. I have talked with a surveyor & he wants & $600 to layout the line.
   / Property line on19.5 acres #2
I may be ignorant of laws in KY but I know that in all instances of my family either buying or selling property involved recent surveys of it to establish accurate boundaries...
I would think that this is the same in your situation...
   / Property line on19.5 acres #3
I'd think with the marker pins in place drive a steel post in at the marker ... may have to add something to it to get it in the air to have a line of site. Drop a section of pipe over the t-post with bright orange paint on it?? The run your line from marker to marker.
There is a recent survey but only the corners are marked not the entire line. This 19.5 acres is 1/4 of a farm that was divided off as a part of an estate settlement.
   / Property line on19.5 acres #5
A 20' section of 2" schd. 40 pvc slid over a t-post would stick up in the air, maybe enough to get a line of sight from one pin to the other. That would allow you to brush out the line and put some flags on trees that are on the line.
But, if you can't see from pin to pin, then it may be cheaper in the long run to pay the surveyor.
   / Property line on19.5 acres #6
have you googled map the land in question for clues where you can add more stakes in between? It may not be accurate, but it should get you close enough.
   / Property line on19.5 acres #7
Maybe your county GIS maps can help. In my county, it's possible to do this online. There is a system which shows all of the parcels overlayed on a searchable map. You can zoom in and see exactly where the property line is.
   / Property line on19.5 acres #8
Timm250,
Here is a trick I did. If you can do this with your hills it is really close. All you need is flash lights and cell phones and two helpers. In the dark, Have helper one stand at first marked pin. You go to the other marked pin. Have helper one turn on their flash light. Call helper two at some mid point turn on their light. Direct them left or right until you and the two lights are in line. Have helper two Place your first T-post. Keep going until you can clearly see all the posts.
When you put your fence in, move in from your line one foot for error
Patrick T
   / Property line on19.5 acres #9
Since the bush is thick and hilly, your only real option for a true location is to hire the surveyor. $ 600 seems like a deal. Make sure his price includes setting intervisible stakes. These can just be wood stakes. Without a survey you may get the fence on your neighbours property and if he challenges the location, you may have to get it surveyed anyway. Just make it a condition of sale that the seller pays for the survey or make an offer of $600 less than what you were going to pay. Do not rely on any GIS overlays. They can be off large amounts.
Al
   / Property line on19.5 acres #10
If the fence was just TPosts I might try to find the line myself. On the other hand, if the fence was more permanent I would pay the surveyor to put in pipes between the corners. I have one property line that is around the same size you are talking about and it has multiple pipes in the ground along the line. However the line is in the woods and hilly with heavy brush. Even with relatively short distances between the pipes I still have not connected the markers along the line because of the think brush. We have other lines 700-800 in length where we have had the same problem because of the woods and heavy brush and we are just trying to cut a line of sight between the two corners not put up a fence.
At some point I will have to pay the surveyor...
Later,
Dan
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2007 Allmand Night-Lite Pro Towable Light Tower (A51691)
2007 Allmand...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
