TODAYS SEAT TIME
   / TODAYS SEAT TIME #2,521
When I used to live on a gravel road in maine i would pull the gravel in from the edge first to save it and then pull it up towards the crown of the road. That's the way I saw a road grader do it. Except, I never used a blade--only an 8 ft rock rake (landscape rake) that kept smooting things as it went. As the weather progressed I kept rock raking in draft control and building a crown towards the road center. It worked perfect.
A rear blade for me proved too dificult for me because the grass growing in the gravel cause "bunching" and I was not able to get it smooth. The rock rake did a great job.
   / TODAYS SEAT TIME #2,522
:jump:Did about a hour and half yesterday pulling some small stumps and rocks for neighbor's yard expansion project.
   / TODAYS SEAT TIME #2,524
I mowed my lawn for the first time too and wouldn't ya know the new blades I put on last fall - 3 or them...well something is amiss..toward the end of my mowing I was leaving an uncut strip behind me about 3 or 4 inches wide right in the middle...of the cut..I hope it is just a blade...I will have to fix it before I mow again...
Always something...:)
   / TODAYS SEAT TIME #2,525
Shoulda got the 22" long blades instead of the 20" long blades. :D
Sorry, couldn't resist. :)
   / TODAYS SEAT TIME #2,526
Carried two old cedars to the brush pile.
First is 26' long, second is 28'.
Second one 17' up, above the pile.
Compressing the pile, notice the front end is off the ground.
   / TODAYS SEAT TIME #2,527
4 day project - dug ~300' trench and laid 2x conduit paths for telecom:
   / TODAYS SEAT TIME #2,528
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=314377"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=314378"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=314379"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=314382"/>
Are you going to burn it? You could build one heck of a bonfire with that.
   / TODAYS SEAT TIME #2,530
Yep, will burn it and two other piles when the wind conditions are right.
Here are two smaller ones from several years ago.
2005 Cat DP40KL Forklift (RUNS) (A50774)
2005 Cat DP40KL...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
Probst Metal Cart (A50774)
Probst Metal Cart...
2025 Swict 60in Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
2025 12V Diesel Pump and Hose (A50323)
2025 12V Diesel...
