Solar power
   / Solar power #21
Before I decided on PV I was looking on wind generators. I was surprised how expensive they were. PV is about half price of wind generator not speaking about reliability. Another problem with wind is that the maintenance is at least 80 ft in air. If you want disconnect PV just flip the switch and you are done. That is not always the case with wind turbine. If your house doesn't use all the energy generated you need to waste some to prevent the machine from furling. In other words the control system might be more complicated than you would like.
PV is not perfect either. It might take lot of space, shading is big issue etc. If you want to use it off grid proper selection of the inverter/controller is major concern for well functioning system.
   / Solar power #22
The company that installed my grid-tied solar system does all sorts of alt energy, including wind turbines. I was asking them about wind and they said they have put a few in and taken most of them back down. People tend to over estimate their true wind resources, at least around here. The central plains states are where the best wind resources are located - in general.
We also have tree-caused turbulence to contend with which means the turbine has to be really high, like 120', and/or be willing to cut a lot of trees.
Given the initial expense, footprint, difficulty of maintenance, as Ladia points out, I would be very certain about wind before purchasing a unit.
   / Solar power #23
PV is boring
that's what I like about it
   / Solar power #24
Wind turbines need to be mounted very high as in 75ft minimum on flat ground and 50 clearance above any obstruction. 40, even 60ft is a total waste of time and $.
Wind turbines should be mounted down wind of your residence or the wining whirling swishing sound will drive you daft. The noise is the reason for 95% of the removals. Lightening strikes and the resulting failures are another.
Wind turbines need to be sized at least 3 to 4 times larger than the actual desired output.
Wind turbines do work at night and on short cloudy stormy days.
   / Solar power #25
I am a land surveror and we did a job for an older couple that had a pretty decent sized array on top of their house. They were very earth friendly people and they did it in an effort to conserve the enviornment. They didn't store any of the electircity, but there meter ran backwards when it was making excess power. This made the cost a lot less for them. They always owe the power company money, but some months the bill it pretty small. They were the first in our area to do this with the local rural electrical co-op.
   / Solar power #26
Power of the wind turbine is proportional to wind speed cubed. Therefore every mph speed increase adds a lot of power. But it works the other way around too. Every mph decrease makes for big loss of power. It also means that energy of strong wind will not be utilized because, without protection, the power generated would twist the turbine like a pretzel.
10 kW rated power turbine produce little less than 16000 kWh/year in 12 mph average wind speed area. Needless to say at ideal condition. Wind turbines are usually rated at 25 mph wind speed.
   / Solar power #27
That's curious. Several of the people I work with have put in solar systems in the last few years and most get money back from the power company every month. But these were probably more recent installs.
   / Solar power #28
The net-metering regulations, under which grid-tied solar systems work, vary widely across the states. It all depends on the state rules.
   / Solar power #29
Reading this thread has inspired me. I have reached out to several companies to get a site analysis and bids.
   / Solar power #30
I've been thinking about it myself
I put up solar out at my barn myself but would want to look into having it installed on my house by the pros
with doing it myself I couldn't take the tax credit advantage
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
UNUSED RAYTREE RMBD72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2013 Ford F-150...
UNUSED LANDHONOR LHR-MS0608 METAL SHED (A54757)
UNUSED LANDHONOR...
