Propane Fireplace
   / Propane Fireplace #11
I currently have a 100 gallon propane tank from Amerigas that I use for our indoor direct vent propane gas fireplace in the winter. I don't use 100 gallons a year, usually only about 50-60 gallons, so they charge me rent plus the cost to fill it up.
My question is, can I get my own RV or grill type tanks and use them instead? Filling them up as needed at the local station or doing a replacement at Lowes or someplace?
Any thoughts?
Thanks for the input.
Wes
You can purchase your own tank but I'd be careful of going to small......would be a pain to always be filling. Also.....your hundred gallon tank does not get filled totally. Most companies fill them to about 80% so you really only have about 80 gallons at max. My question.....why do you consider your existing tank a problem?? So you have 1.5 years supply of propane. It doesn't go bad.....fill it up is summer when prices are lower and enjoy.:2cents:
   / Propane Fireplace #12
The TSC site said those are 100 pound tanks for $140. woops typing faster then my brain was working.
   / Propane Fireplace
My issue is with Amerigas. They charged me the highest rate in town last year and a rental fee. The rate I paid for propane was $3.675 per gal. Then to add another $100 rental fee on top of that is crazy! Divide that over the amount of propane and it is a cost of $5.35/gal! To avoid the rental fee I have to purchase at least 60 gal per year. Last year was only 59.4. Needless to say I called and complained and finally the manager waived the rental fee.
When I called around to other companies they were in the $2.25 / gal range, one was even $1.89!
It looks like I will be stuck with them though since all of the local companies are now bought out my the big companies who do the same thing as Amerigas.
   / Propane Fireplace #14
Can you T into your tank line and run your grill off of that tank? This would help to increase your usage, and eliminate tank fee's.
Dave
   / Propane Fireplace #15
I understand now........the 100lbs tank is $129 at Lowes. Good luck!
   / Propane Fireplace #16
With a pilot light, every time you would swap out tanks the pilot would go out.
Once I got air in the whole piipe from the tank to the fireplace, it was a pain to relight.
   / Propane Fireplace #17
Not really, I thought it danged odd to advertise the tanks in pounds to begin with. Just happened to catch it.
Online Buyers Premium (A47477)
Online Buyers...
2007 International 4300 Dump Truck (A51692)
2007 International...
2018 Kubota U17 (A53314)
2018 Kubota U17...
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
2005 Ford F-150 Pickup Truck (A55852)
2005 Ford F-150...
