Shearng the bolt pin on bush hog with John Deere 990
   / Shearng the bolt pin on bush hog with John Deere 990 #1
pianokey50
Bonaire
John Deere 990
Does anyone have any tips on what I could look for with reference to the following: I have a John Deere 990 Tractor. Almost everytime I try to use the bush hog, when I go to engage the PTO, the bolt pin shears. Thanks
   / Shearng the bolt pin on bush hog with John Deere 990 #2
Are you trying to engage at idle speed?
   / Shearng the bolt pin on bush hog with John Deere 990 #3
How worn is the shaft or part the shear bolt fits into . And agreed as Tx Jim suggested to idle engine then increase speed and bush hog increases spin.
Proper sized bolt also not hardened .
ken
   / Shearng the bolt pin on bush hog with John Deere 990 #4
Idle speed is probably the key... But do lift the cutter and look under it in case there is something blocking the blade, like a piece of bent metal. Try to turn the blade by hand. If it doesn't turn freely than it could be frozen for a number of reasons.
But you are probably just engaging it at full rpm.
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
MISC ITEMS (A53843)
MISC ITEMS (A53843)
BUSH HOG BH215 - 5' ROTARY MOWER (A51406)
BUSH HOG BH215 -...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A54607)
2017 INTERNATIONAL...
SET OF (4) NEW 11R24.5 TIRES (A53843)
SET OF (4) NEW...
SAND BLASTING CABINET (A53843)
SAND BLASTING...
