Ford 1900 injector pump oil
   / Ford 1900 injector pump oil #1
Dresding
Branchport NY
IH-H, IH-444, Ford 1900, IH-C IH-360
I have a Ford 1900 and no manual.
What oil is used in the "Oil Plug" fill on the injector pump?
This is the first injector pump I've seen that has an oil cap on it!
   / Ford 1900 injector pump oil #2
Typically injection pumps with self contained oil reservoirs will take motor oil(whatever the engine takes) and should be changed when engine oil is changed. There will be a drain plug on the bottom and a level plug about a third the way up on the side of the pump housing.
   / Ford 1900 injector pump oil #3
common on inline pumps or non fuel lubed pumps like the rotary used on some fords.. etc.
put crankcase oil in there. like 15w40 c rated.. etc.
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52128)
Heavy-Duty...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
