Ford 1220 Starts 1st time, shut it off and won't start again.
   / Ford 1220 Starts 1st time, shut it off and won't start again. #1
fishnfarm
City, MO
Ford 1220
Hello. First time poster on here. I have a little Ford 1220 4x4 w/ loader. It will start up fine the first time and run for as long as you want but when you shut it off, it doesn't start again until it sits for a long time. Where should I start? Any help is much appreciated.
   / Ford 1220 Starts 1st time, shut it off and won't start again. #2
When you say "...it doesn't start again....", do you mean the starter wont turn the engine over OR the starter does turn the engine but it won't start and run? The former is a problem with the starter electrical system and the later may be a problem with the fuel delivery system. You have to be more specific on these forums to get help because most of us are not mind readers.
Sorry about that. The starter does turn the engine over but it will not start and run.
   / Ford 1220 Starts 1st time, shut it off and won't start again. #4
If you can't hear the fuel solenoid open (click) when you turn the key, the solenoid, or more likely, the 'open' signal to the solenoid may be weak. One way to check is to put 12V on the fuel solenoid (using Powerpack or jumber cables) and try to crank.
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2012 INTERNATIONAL LF687(INOPERABLE) (A50854)
2012 INTERNATIONAL...
