JDTank
- Joined
- Oct 5, 2010
- Messages
- 693
So I ordered a set of gator blades for my X740 with the 54 inch deck, from my local JD. After ordering, I read some reviews claiming the performance is actually quite bad on these. Is this true? A few years ago I read raving reviews, now, not so much.
I have heard the hi-lift blades are the best way to go?
I do not bag clippings, I side discharge, always. 30% of the time I am cutting high grass in fields, about 10 inches tall. The rest of the time I am finish mowing about 2 acres of lawn. I also read that hi-lift blades will pick up rocks and throw them. Do these really create that much suction? Also, I noted in some information I found, fuel consumption increases with hi-lift blades due to resistance, but those are likely small gas powered riding mowers. I have my doubts that my diesel engine in my X740 will notice that kind of difference.
My goal is to have fine clippings that disappear in the grass, so you couldn't tell the difference between bagged and discharged. I am also looking for discharge distance. Right now I am using the blades that came with the mower deck, and I am not overly impressed. The cut quality is good, but the build-up on the underside of the deck is quite bad, and happens quickly. Also, the discharge distance is a few feet, not what I was hoping for.
Do hi-lift blades, or gator blades, keep the underside of the deck cleaner?
Looking for some experience from those who have run these blades on these decks before.
Thanks!
Thanks!
