Belt squeal on new X738
   / Belt squeal on new X738 #1
jbgood
Member
Wisconsin
2013 JD X738
Took delivery of a new 2013 X738 and love every part of it. Auto connect 54" HC mower deck, Auto connect snow blower. They both go on very easy. All of the other features are great and perform well. The only thing that annoys me is the fan belt. When you first start it and about until 10 min. later the belt squeals. The belt is tight and I have spoke to others who have the same problem on tractors and gators. Question is : Anybody else had this prob. and how did you cure it ? Dealer says this is common on many J.D. products and goes away with time.
   / Belt squeal on new X738 #2
Where's the pics?! Took delivery of a 2013 and you didn't leave tons of photos with an in-depth review....tsk tsk tsk.
As for the belt squeal, wait a while, it will go away. Since the belt is new, the rubber is soft and very grippy. Once the surface of the belt wears a little it will stop.
   / Belt squeal on new X738 #3
Auto connect snowblower?
There really shouldn't be any squealing from the fan belt, but I suppose in time the pain on the pulleys may burnish in a bit and it should stop.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55218)
Ditch Witch 6510A...
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
Toro Zero Turn (A50324)
Toro Zero Turn...
CATERPILLAR 615C MOTOR SCRAPER (A51406)
CATERPILLAR 615C...
