3-Point Hitch B7200 3PH lift arm bent
   / B7200 3PH lift arm bent #1
Superbird
Virginia
Kubota B7200D
Just bought a B7200 about a month ago.
Should I be concerned about the right lift arm on this hitch? Tractor will be used for mostly moving snow with a scraper blade, moving trailers now and then w/ drawbar, and some plowing with a middle buster. I live in Va so we don't get a lot of snow. Looks bent to me.
Thanks!
   / B7200 3PH lift arm bent #2
Is it on backwards? Could you turn it around and see if it looks "straight?"
   / B7200 3PH lift arm bent #3
Yours is bent very little and should present you with no trouble. The lift arms for mine were alittle pricey so I have been running mine for years in this bent condition. I had a 730 Arps backhoe on my small "L" model. Used the hoe and raised the three point lift on the tractor to it's highest point. Then I climbed up on the backhoe and raised the outriggers. Everything was fine until I drove it back to the house. They bent but did not break. Mine could be switched left for right and it would put the bend in a upward way. Never have done that as I used vertical adjustment to keep drawbar level.
Skid steer auger plate (A50322)
Skid steer auger...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
