12 volt conversion
   / 12 volt conversion #1
MODELTR
memphis,tn
ford 851
When converting from 6 volt to 12 volt is it necessary to replace gauges with 12 volt gauges?
Thanks
   / 12 volt conversion #3
   / 12 volt conversion #4
Thanks
your gauges left the factory as all mechanical. at best.. you have some lamp elements to replace.
when you change coltage check any gauge and dash and head lamps.
and get a new coil / coil / resistor combo appropriate to the type of 8n you have. obviously the charge system and battery are being updated.
key switch is fine.. starter and soelnoid are fine.. etc..
   / 12 volt conversion #5
good grief. what a suggestion. :(
I wasn't suggesting that he had to use a voltage converter, I was suggesting that if he had electrical gauges, as opposed to mechanical gauges, it is an inexpensive option rather than buying new gauges.
So what's with the sad face? :(
   / 12 volt conversion #6
it's a 45$ answer to a 10 cent question.
way to much wireing to get a dc to dc converter ... besides. just not many options you see for electronic gauges on these.
the temp gauges are bulb style.
the oil pressure gauge is bourdon style.
proofmeter is straight mechanicale / cable driven off the hydro pump nose.
etc.. etc...
Thanks soundguy,Really appreciate your help!
Travelover,Thanks for you help and suggestion!
   / 12 volt conversion #9
way to much wireing to get a dc to dc converter ... .
No, you can buy a 2 amp Dc-Dc converter for $1.75. And it is 2 wires in and two wires out.
besides just not many options you see for electronic gauges on these.
The OP didn't say whether the gauges were original, nor specify mechanical or electrical
etc.. etc...
I agree, with mechanical gauges, he should just change the light bulbs. If the gauges were electrical, an small DC-DC buck converter is an inexpensive way to power them off a regulated 6 volts.
   / 12 volt conversion #10
I would not call the voltage off a genny with a vibratingstyle mechanical regulator 'regulated 6v'
you will see large % excursions from 'regulated 6v'... if the gauge in question relied upon regulated 6v for accuracy.. you may see innaccuracy. if it did not care about the exact voltage.. like a sender and on / off lamp.. not a biggie... can't say that i see lots of 6v vintage electronic gauges in these machines....
in any case. it's a way, way moot point.
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2014 INTERNATIONAL MA025 (A53843)
2014 INTERNATIONAL...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
