need new greese gun any ideals
   / need new greese gun any ideals #11
The Lincoln lever style guns are rated for 10,000 psi while the pistol grip style are rated for 7200 psi. Their air powered guns are rated for 6000 psi when supplied with air at 150 psi while their standard duty cordless guns are rated at 6000 psi. Their heavy duty 2 speed guns are rated for 7500 psi (the Milwaukee gun says theirs is rated for over 8000 psi). Most cordless grease guns I've seen are rated from 6000 psi to over 8000 psi. I'll always have a lever style gun for a backup but if a cordless or pistol grip style gun doesn't have enough pressure to get the job done then what's really needed is for the zerk to be replaced and the grease passageway to be cleaned out. I'm not saying that I'm great about servicing them but I would before giving up on an electric gun.
   / need new greese gun any ideals #12
I have used cordless grease guns, Lincoln and John Deere branded ones to adjust track adjusters on a 650 deere dozer, 790 deere track hoe and 200 lc deere trackhoe for several years, also done all the other greasing with them also, track adjusters are not that easy on these machines. I like the cordless ones alot. Also like pistol grip grease guns too. LUTT
   / need new greese gun any ideals #13
I've used the Milwaukee cordless, and like it plenty. It's built stout and yet doesn't weigh too much. The specs say it will pump seven cartridges per charge, so one battery is plenty for me. I've got arthritic hands and this is the easiest greasing I've done in a long while.
   / need new greese gun any ideals #14
I like to read or feel the grease going in, so I stopped using anything but a manual grease gun. I know its a pain at times using the lever type but at least you can feel the grease going in. With a air grease gun you could have a gummed up grease nipple and you would never know it.
well i got my new greese gun today 14.4 volt linclon. my buddy that i have helping the past month has one and it works great. we replace alot of front ent parts and it gets used alot. so if mine works as well as his it's the only one i'll ever need.
   / need new greese gun any ideals #17
Any reason to buy a battery powered gun over an air powered if it always gonna be used near an air supply?
Looking to upgrade, battery guns are way more expensive, but seem more popular. Not sure why
   / need new greese gun any ideals #18
ok how often to these electric greese guns need to be charged. I like the idea of one hand pumping and one holding the zert, but i dont greese that often. so my gun sits a while then gets used.
I guess im asking how well the work after sitting a while.
thanks
i have spent alot of money over the years on air operated greese guns. my biggest complaint when you run out of greese and put new tube in it takes for ever to get the air out. may just be the way i use them but i couldn't get them to last very long. when i picck something up to use it i want it to do what it's suppose to do. my buddy has had this one about 2 years and uses it every day and hass had no problem.
I guess im asking how well the work after sitting a while. the battery is suppose to last thru 7 tubes of greese. my buddy says he charges his about once a month. as far as how well they work after sitting around i don't know.
thanks
   / need new greese gun any ideals #20
thanks
Same as a cordless drill as far as sitting for a while. We have 4 at work and we like them a lot. We always keep some batteries in the charger so we always have a fresh battery when needed. We have plant air and used to have air powered ones but like the cordless much better. Much easier than dragging a hose all over around a machine, conveyor etc.
2012 International 4300 ExcaVac HT-280 Vacuum Excavation Truck (A51691)
2012 International...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
2011 Ford Fusion SE Sedan (A51694)
2011 Ford Fusion...
B&W 5th Wheel Hitch (A53117)
B&W 5th Wheel...
2015 John Deere Z950M 70in Zero Turn Commercial Mower (A51691)
2015 John Deere...
