New/Old Oil -- Pitch or Use?
   / New/Old Oil -- Pitch or Use? #1
jeffinsgf
Springfield, MO
JD 4410
Cleaning the shop today and found several sealed bottles of Stihl 2-cycle oil in a bottle size that was wrong for the gas can I was using, so they went to the back of the shelf and forgotten for 6 or 7 years. Similar story on several sealed bottles of 30 wt oil I bought for my various 4-cycle engines.
Do engine oils go "bad"? Can I use these or should I take them to the waste disposal place?
   / New/Old Oil -- Pitch or Use? #2
That oil is as good as it ever was .Just like toilet paper .
   / New/Old Oil -- Pitch or Use? #3
As I finished reading the OP's post I was prepared to say "the oil is as good as it ever was",,,,, but I was not prepared to compare it to toilet paper!!! Good One Kevin!!!! Is it alright if I use that analogy in the future??? :thumbsup:
   / New/Old Oil -- Pitch or Use? #4
The stuff is in the ground for x million years and is still good so in a sealed container for a handful of years won't hurt. Use it and count it as a windfall.
   / New/Old Oil -- Pitch or Use? #5
Some people do say that the additives will drop out, Personally I would use it, but do shake the container upside down for a while to remix it.
Just a thought!
   / New/Old Oil -- Pitch or Use? #6
i for sure have 2 cycle oil that old I still use.
   / New/Old Oil -- Pitch or Use? #7
If in sealed containers I for certain would use it. If you prefer not to, you could use it for bar oil in a chain saw.
Thanks, you guys. I was inclined toward using it, but wanted to check with the "conventional wisdom".
   / New/Old Oil -- Pitch or Use? #10
I assume the Stihl saw is old too where warranty doesn't come into play? Stihl has a warranty thing with new saws that requires using Stihl Ultra 2-cycle oil. I was told they will test for it if the saw goes for warranty work.
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55301)
Michelin CARGOXBIB...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Ingersoll Rand 60Gal. Air Compressor (A52377)
Ingersoll Rand...
John Deere Bale Spear (A55218)
John Deere Bale...
