Hydraulic Hoses
   / Hydraulic Hoses #1
Rvrrat14
Member
Texas
Yanmar YM347A, Bush-Whacker HD72, Armstrong BGR64-5 grapple, Homemade 66” Box Blade
Can someone tell me which type hoses I need to run from the rear remotes to the front end loader to operate a grapple? This is for a compact tractor in the 40-45 hp rating. Also, any places to buy/order on the net at the best price. 3/8" i would susspect. THANKS. A Kioti DK 40 SE or LS R4041.
   / Hydraulic Hoses #2
3/8" hose would be the best choice. 1/4" would probably work given the intermittent use of grapple cylinders. Buy local or online, it's your choice. If you want to figure the lengths closely and have custom lengths made for a super neat & tidy installation, use a garden hose as a measuring device to ensure proper bend radii are planned for. Some online vendors sell good hose relatively cheap, some sell garbage. Local shops that make hose to order will likely sell Weatherhead, Gates, or Parker Hannefin, all good quality manufacturers.
   / Hydraulic Hoses
Thanks. What about pressure rating?
   / Hydraulic Hoses #4
I'm in the 1/4" camp for a grapple. It's cheaper and easier to route.
You might not want two long hoses (probably 20' or more) but rather shorter sections with QD's to make the loader/grapple easier to remove. Like one set from the rear to the mid section where the FEL connections are, then another set from there to the end of the FEL, then to the grapple. More $$$, but more user friendly as well.
Ricks suggestion of the garden hose is spot on (his advice always is), just mark it with masking tape, then lay it out straight and measure. Use wire ties/zip ties to hold it in place.
   / Hydraulic Hoses
Good idea on breaking it at FEL. 3000 psi, thanks.
   / Hydraulic Hoses
If I go 1/4" and the grapple comes with 3/8" hose, will that be a problem with operation/fluid delivery?
   / Hydraulic Hoses #9
I suggest you buy the grapple without hoses, that way once its mounted to your machine you can measure for the proper length. But to directly answer your question, no.
   / Hydraulic Hoses #10
I have a grapple and used it for several years with the 3rd function switch on the FEL joystick, and that worked well. I subsequently had a problem with the 3rd function solenoid and bypassed it and ran hose from grapple to rear remotes as you are planning to do. I found it was nearly impossible to operate the grapple in any coordinated way using the rear remote. Now I have fixed and reinstalled the 3rd function on the joystick and it is a joy. I recognize the extra cost, but I'll bet there will be many times you wish you had invested in it. I found that without the 3rd function on the joystick, I would have needed a third hand. Now, possibly this is because the joystick and the remote levers are on the same side of the operator's platform on my tractor...but, anyway, think about it.
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
2008 Genie ManLift (A50322)
2008 Genie ManLift...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A51222)
2013 FREIGHTLINER...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
