How to smooth a rough yard
   / How to smooth a rough yard #11
Core aerator and drag.
curious about this myself. My dads and my yard are fairly rough. Frost heaves gofer mounds. More lumpy than ruts or bumps. Would this approach fix my problem. Large lawn roller has not worked.
Well, I'd need more information to make a good recommendation. Are the rough spots high ridges or ruts? It makes a difference because generally you need to remove high spots and fill depressions. If there are high spots, will cutting them down create an overall low spot in the yard that will collect water and be a Spring time mess? The first thing I thought of when reading your post was that possibly someone in the past took a tractor into that area while it was waterlogged and just left a rutted mess. I'd usually suggest tilling when dry enough in different directions and it will pretty much self level, but without a tractor your options are very limited. Depending on how large an area we're talking about, you can get a load of topsoil and fill in the rough areas by hand. If you do this, allow for some settling of the soil. A better option is to ask a neighbor with a tractor for his/her opinion and advice. They can look at it, evaluate it, figure out what equipment is needed to fix it, and probably be willing to help you out for minimal cost if they can. I'd do it for nothing if it wasn't of an unreasonable size just to be neighborly.
You don't see high or low spots....it slightly slopes, but looks even. I think nwltruck description of lumpy is the best description. And you don't see the lumps...but you feel them. This is fescue, and part of it is an uneven growth...but that's not the whole problem. I've thought of using a lawn roller...but seems nwltruck tried that and did not work. I wish I had a tractor (which I'm working on) with a lawn rake to go over it to pull some of the dead stuff out, then overseed more fescue.
   / How to smooth a rough yard #13
I believe so. I currently have a 3'/small 3PH mount core aerator on order. The ability to work well defined small elevated areas should be a key factor. :confused3:
larry
   / How to smooth a rough yard #14
I'll add another vote for core aeration and dragging. It does the turf a lot of good and evens out both ridges and ruts. Don't stop the aerator until it looks like you've gone way too far. Holes 2-3 inches apart is not too much. Don't pick up the plugs, just drag them with a weighted chain link fence section (I have a gate).
   / How to smooth a rough yard #15
Just conjecture from observations using a chain drag -- you want a drag that bridges the low spots instead of conforming with the surface.
larry
   / How to smooth a rough yard #16
Just to be clear, I'm not talking about a chain harrow. This is a framed chain link fence gate with some weight added to the top. It doesn't conform to the low spots, it bridges them, as you say.
   / How to smooth a rough yard #17
Would a spike harrow do the same or would something with more ground contact be better? Does it have to be a plugger or spike aerator?
   / How to smooth a rough yard #18
:thumbsup: Weighting the frame is the way to go.
larry
   / How to smooth a rough yard #19
I dont think a spike aerator would work because it brings up little or no dirt to redistribute.
larry
   / How to smooth a rough yard #20
A way that works well for me is to approach things in late August when the ground is burnt up and dry as a bone. Drag a disc harrow over it with cut-out blades and then use a Brillion seeder or at least a heavy packer to press the ground down. You don't chew it up too heavily and the understory of grass will pop through when it rains. As well, I add some new seed and this has worked for me.
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55218)
GMC 3500 Extended...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
