1/4" OD diesel fuel line
   / 1/4" OD diesel fuel line #1
BoostedEcotec
NC
Ditch Witch 3700 / Yanmar F20D
I need 1/4" OD diesel rated fuel line for the injector return lines. I went to our local John Deere store but got a blank Homer Simpson stare from the idiot at the parts counter. He said they don't carry fuel line that small. When I asked him what they use in their service department he said he had no idea. None of our parts stores carry anything smaller than 1/4" ID which is too big. As a temporary fix I cut some two inch strips of 1/4" air tubing used in aquariums and inserted those strips into the 1/4" ID fuel lines from Autozone and clamped them but i'd rather redo all of the lines with the right fuel line. If anyone has a link to the right stuff I would greatly appreciate it.
   / 1/4" OD diesel fuel line #2
Go back to the JD parts person with this info in hand.
Part Number: TY22551
Part Price: 0.88 USD
On Hand: 57 Check Other Stores
Description: FUEL& OIL HOSE 1/4",SAE30R7,25'ROLL
Specification
Weight 0.11 LBS 0.05 Kg
Inside Diameter 0.250 IN
Length 300.000 IN
Material 30R7
Finish
Note
Specification
Length 300.000 IN
Material 30R7
Finish
Note
Looking at that info it shows the inside diameter to be 1/4" which would be too large. I believe the 1/4" OD (outside diameter) hose has an inside diameter around 1/8" which is very small. I inserted the 1/4" OD air hose into some 1/4" inside diameter fuel line I purchased from AutoZone as a quick fix. The fuel line and connectors on the injectors and the "T" fittings are very small. The aquarium hose would work perfectly if it could stand the heat and fuel but I doubt it would hold up. Both my 3700 and F20D have this same size hose that return the fuel from the injectors to a 1/8" x 1/4" type of fitting and then back to the tank.
I hope this makes sense. It's very small.
   / 1/4" OD diesel fuel line #4
Sorry my mistake. What machine are you wanting fuel line for? What brand is 3700 & F20D?
I found this hose.It's fairly small but larger than 1/8" ID.
Part Number: M88201
Part Price: 21.86 USD
Description: HOSE, 10 FEET SERVICE
Weight 0.84 LBS 0.38 Kg
Inside Diameter 0.187 IN
Length 120.000 IN
Material 30R7
Part Number: M88201
Length 120.000 IN
Material 30R7
I have a DitchWitch 3700 with a Deutz F3L1011F 3Cyl and a Yanmar F20D 3 Cyl. Both tractors have the exact same size return lines so I was hoping this would be more common. These fuel lines are not the larger supply line rather the smaller return ones. The main thing is the lines cannot be clamped so they need to fit nice and snug.
Is that a JD part # also? My local JD outfit has absolutely NO customer service skills whatsoever so I try not to go there if at all possible. I know some JD tractors have Yanmar engines so I would think the service department would replace these from time to time. The guy at the parts counter couldn't get rid of me any faster.
   / 1/4" OD diesel fuel line #6
Yes the numbers I posted are JD PN's. Being a retired/retarded EX JD parts person I kinda know how to look up JD parts. The last PN I posted was off a JD 950 which is built by Yanmar.
   / 1/4" OD diesel fuel line #7
Yes the numbers I posted are JD PN's. Being a retired/retarded EX JD parts person I kinda know how to look up JD parts. The last PN I posted was off a JD 950 which is built by Yanmar. I suppose if I had read your profile I could have determined what machines you were referring to.
   / 1/4" OD diesel fuel line #8
Go to your local small engine repair shop and get some Tygon gasoline hose. It comes in many very small sizes. I
keep about 4 sizes in stock around here cuz I work on a lot of small engines.
The 1/4" soft PVC air lines that you used are OK for a while, but will harden up eventually. Diesel
fuel is easier on most plastics vs. gasoline.
Thanks, Jim.
My JD closed at 12:00 pm today so I'll stop over Monday and see if the parts guy has time to look it up for me.
If not, I'm thinking something like this maybe...
Premium Quality Tygon Fuel Line 1 8" ID x 1 4" OD by The Foot 695541 | eBay
Below is a pic of the different hoses. The small unmarked black hose is the original. Above that is three hoses connected together. The smallest to the left is 1/8" max power fuel line inside the 1/4" aquarium hose which is inside the 1/4" fuel line I purchased from AZ. The 1/8" max power hose is too small but it fits inside the 1/4" air line which makes me think that 1/8" ID hose is what I need. I tend to over think things.
Your post came in as I was responding to Jim. I went ahead and ordered a few different sizes from the ebay seller that I linked in my response to him. I live out in the Country so it's easier to order stuff than to try and find it an hour away.
Thanks.
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
20X30 ALL-STEEL CARPORT W/ ENCLOSED SIDEWALLS (A53843)
20X30 ALL-STEEL...
