tc 45d fuel tank leak
   / tc 45d fuel tank leak #1
Iabadger
Ames Iowa
New holland
I found a feul tank leak behind the seat where two bolts are placed into the side of the fuel tank. the leaking bolt is apparently stripped and cannot be removed. The pictures tell the story. Do I need a new tank or can this be repaired?
   / tc 45d fuel tank leak #2
Welcome!
There seem to be some products out there that will repair plastic diesel fuel tanks. Maybe you could apply those sealers over and around the molded-in nut after removing the bolt? The stripped bolt may back out if you can pull on it and turn at the same time.
I would leave the hold down strap off and replace it with duct tape. :rolleyes:
VersaChem/1.06 oz. plastic gas tank and radiator repair kit (90215) | Fuel Tank and Radiator Epoxy | AutoZone.com
Professional Repair Systems : Permatex® Plastic Tank Repair Kit
POLY TANK REPAIR KIT (MANUAL MIX) - Mr Sticky's Premium Adhesives
leaking plastic tractor diesel fuel tank - DoItYourself.com Community Forums
"it can probably be repaired with a fuel resistant epoxy or jb weld by roughening the area around where its leaking with some sand paper and cleaning the area and appling the epoxy if you can acces it it may be able to be done on the tractor once you drain most of the fuel if you cant get access you may have to remove the tank."
Thanks for the help
   / tc 45d fuel tank leak #4
Thanks for the help
Well, it wasn't much help. I wish I could say I had a leak and this is what fixed it, but I'm glad I can't on the other hand. :laughing:
Your post may me wonder what I would do if I did have a leak.
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
UNUSED CHERY INDUSTRIAL 7' - 10 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2021 BOBCAT T64 R-SERIES SKID STEER (A51246)
2021 BOBCAT T64...
JOHN DEERE 700M LOT IDENTIFIER 35 (A53084)
JOHN DEERE 700M...
2022 LMC H40024 LOT IDENTIFIER 192 (A53084)
2022 LMC H40024...
