John Deere 650- hard to get into gear
   / John Deere 650- hard to get into gear #11
Sounds as if traction clutch is warped or pilot bush(brg) is dry.
Thank you very much. Looks like a fairly easy job to do . I think I'll order a clutch kit. Are there any aftermarket companies or just oem
   / John Deere 650- hard to get into gear #13
If you don't know already,your tractor is 100% Yanmar-made in Japan. You can look up parts on the John Deere site,but they don't cary much for them anymore.(jdparts.deere.com)Their price for the disc is $376.41 and the pressure plate is $292.14!!! There is a clutch kit on Ebay for $163. You can get a clutch from Yanmar Tractor Parts - Shop Online (Yanmar) also.Look down at the bottom of the model list to find John Deere.Lots of other Yanmar dealers carry parts too.
Thanks a lot. I was aware it was Japanese made so its great to go to Yanmar. Is that shaft supposed to stop when you have the clutch depressed? I think the unit will have to be split and a whole new clutch put in.
   / John Deere 650- hard to get into gear #15
It just might be the polit bearing and clutch might be ok. I would split it first and have a look.
   / John Deere 650- hard to get into gear #16
YES the input shaft should stop spinning shortly after clutch pedal is depressed.
2013 PETERBILT 367 HOT OIL UNIT (A53843)
2013 PETERBILT 367...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2018 DIAMOND C 40 FOOT GOOSENECK (A53843)
2018 DIAMOND C 40...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
