Bob Rooks
Elite Member
Hi Bill,
I just purchased a brand new pt 50 after 9 hours it has oil on top of number 4 piston they clame we put it on its nose which is false we have had injectors tested and the number number 4 was the best number 1 is stuck open and 2 ,3 are bad we have no warranty because they say we drove it up big hills which is wrong biggest incline measures 15 degrees so we are not impressed they say if you put it on its nose for 10 seconds your engine pretty much blows up any thoughts would be appreciatted
Did you follow a break-in procedure for the engine? Sounds like a broken piston ring (s). Are the oil pans flat on the bottom and without baffles? If so, they don't belong in that application. Oil pans should have a deep V center with the oil pickup down very low. This is also a strong argument for a transverse engine going up and down steep inclines. Also thinking there should be an inclinometer alarm.
