Legacy xl runs VERY Hot!!
   / Legacy xl runs VERY Hot!! #1
bebop86
NJ
Used the tractor to mow some high grass yesterday for a few hours- Today upon start up the engine is running VERY HOT!!- I shut it off- checked everywhere for clogging nothing found- What would caused the engine 25 hp?? Kohler to run so hot and what should I look for thanks so much!! Actually the unit is the Massy 2925 which is the same as the Legacy -it is about 7=8 years okd and always maintained-- thanks again
   / Legacy xl runs VERY Hot!! #2
Did you ever find out what is causing this. I have a 2003 2925 and it started running hot this summer. Cannot figure out the cause.
   / Legacy xl runs VERY Hot!! #3
Did either of you figure this out? My '03 2925 is running hot now for a couple of years. Now it is shutting down when it gets hot and will not start until it cools for about an hour. I think this new problem might be the ignition modules. I did check for vacum in the fuel tank and it still would not start after opening the cap.
   / Legacy xl runs VERY Hot!! #4
Mouse nest in the cooling fins under the engine cowling?
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2014 FREIGHTLINER...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2005 National RV Inc. Dolphin LX RV (A53117)
2005 National RV...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
