X300 Transmission noise
   / X300 Transmission noise #1
topstoy
Tonasket, WA
JD 2520 / Kubota KX121-3
My transmission is starting to make a load howl or pully wine, or somewhere inbetween. Yet it still has plenty of power and not slipping at all. Is this an early sign of the classic transmission failure of the K46 or something different? I am guessing that it is on the way out and just a matter of time before it fails. Hopefully it will last until fall. Really need it to last all summer as I mow every 4-5 days. Thanks
   / X300 Transmission noise #2
I don't think you will make it.
   / X300 Transmission noise #3
If it is internal noise, then you may be able to extend its life a bit by upgrading to 5W50 synthetic, if you haven't already. Since you have to pull the transmission to change the oil, I'd open the case and at least change the filter, clean the magnets and add drain plugs. With a bit of maintenance, you may get a few more seasons out of it before it has to be rebuilt.
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55301)
PENDING SELLER...
