What size tank to get for a MIG?
   / What size tank to get for a MIG? #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
Looking at getting a Everlast Power I-MIG 200 in the not too distant future and I am going back and forth on what size tank to get.
I have an Airgas shop on the way to work and a TSC within "striking range" at lunchtime so I will be buying from one of them (probably the Airgas place as they are cheaper). Looking at getting either a 40CF bottle or a 80CF bottle for 75/25 gas.
The 80CF bottle costs $80 more to buy, but only $10 more to refill, so in 4 tanks of the 80CF bottle I will save enough to pay for the larger bottle.
How much gas should I expect to use per pound of wire? Would be nice to get the larger tank, but not if it will take 5 years to go through 4 tanks...
Thanks
Aaron Z
   / What size tank to get for a MIG? #2
I can't imagine having anything smaller than the 250 cf bottles.
   / What size tank to get for a MIG? #3
get the 80cf.
figure your use by dividing your use rate into the tank capacity.
15 cf/hr use and 80cf tank = 80/15= 5.3 hrs. weld time.
Not sure how that works out to pounds of wire though.
In general, get the biggest tank you can handle.
The biggest size my LWS sells was 80cf, so that's what I got. If they would sell the 125cf I might have got that instead.
You also do a little bit more welding than we will be doing...
get the 80cf.
Thanks. Looks like Tractor Supply sells a 125CF tank for $320ish. Not sure I will be going through enough gas to make that pay off...
Aaron Z
   / What size tank to get for a MIG? #5
I'd recommend no less than 125. It's not practical, and you'll likely be using closer to 20 or 25 cfh in real world conditions with MIG. That's not a lot of welding, a couple days or so. It goes a lot quicker than you think...and when you see 500 lbs show up "magically" on your gauge on the weekend, you'll get plenty nervous.
   / What size tank to get for a MIG? #6
whatever you get be sure to save your receipt. If you ever have to have it filled someplace else, they might not sell that size and might give you a hard time. I've heard of some places that will try to "confiscate"(steel) your tanks as if they were missing lease only tanks.
   / What size tank to get for a MIG? #7
Depends on how much you weld. I just fix a few things every now and then. No real fabricating so to speak. Maybe go through 3 to 4 40 cf tanks a year. My gas supplier is open 6 days a week and a few minutes away. He just swaps out the tanks. I keep a spool of flux cored wire for emergency. Again though, if I fire my welder up twice a month I am lucky and then it is only to fix a bracket or weld a nut on a striped head.
   / What size tank to get for a MIG? #8
IMHO the 80's are a good size for the hobby weldor. Easy to handle, don't take up so much vertical storage space and last a decent amount of time. I personally own three of them.
   / What size tank to get for a MIG? #9
A 125 is a good size but don't go below an 80. Compare the cost of refills and you'll find there's very little difference. The reason is because it is the same labour to hook up a small cyl. to fill as a large one.
   / What size tank to get for a MIG? #10
I agree. I think I've refilled my 125 3 or 4 times in the year I've had it. I wouldn't want to go smaller.
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
New Holland B95B (A50123)
New Holland B95B...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2011 KENWORTH T800 (A53843)
2011 KENWORTH T800...
