Fencing tricks for hole depth?
   / Fencing tricks for hole depth?
Thanks guys.
The fence has to follow the contour of the land.
I ended up making a story pole. I used an "L" shaped bracket on top which would hang on the top of the post. On the bottom I of the pole I put a horizontal brace that would span across the hole. I would set the story pole on the ground and then look to see how the top of the post lined up with the "L" bracket on the end of the pole.
My poles probably varied in about a 4" range in overall height. As long as I was between 8 foot and 8 foot four inches I called it good.
   / Fencing tricks for hole depth? #12
I once saw a fence company set posts to the approximate depth, build the fence, then trim the post tops to make them even.
If you really care, I think this is the only sure thing. I think there are just too many variables any other way.
   / Fencing tricks for hole depth? #13
I agree. That is the way I did it for a board fence I built last fall.
   / Fencing tricks for hole depth? #14
We do it by eye, old fenceman's trick. I always laugh at guys with strings and wires because the last thing they do is check it out by eye.
   / Fencing tricks for hole depth? #15
That don't work in our world. You see my father, he's now 87, taught us that you always cut off the bottom of the post to set it for height.
   / Fencing tricks for hole depth? #16
When building hi tensile or woven wire, I drive the posts to approximately chin height and call it good. The exception being when the post hits an un-moveable object, then I'll trim the top.
(50) 2" X 2" X 20" TUBING (31) 10" X 3' CHANNEL (A57192)
(50) 2" X 2" X 20"...
Kubota M5-111 (A53317)
2012 ford focus (A56859)
2012 ford focus...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Katolight SED40FJ 40 kW Generator (A55851)
Katolight SED40FJ...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
