How do you check Hydraulic Fluid in MF 255
   / How do you check Hydraulic Fluid in MF 255 #1
NickReininger
Geronimo, TX
MF 255, IH 1086, IH 300
I know this sounds like a dumb question, and I even bought a service manuel on line yesterday and still cant figure out. How do you check the hydraulic fluid on a MF 255? I just bought this tractor, and have never owned a Massey before.
There is a small dipstick located on the right side underneath the seat right next to a little lever. Is that how you check the fluid? also what is that little lever do?
And where do I put the fluid in? there is a big nut that you unscrew right before the stick shift. When I take the nut off and look in the case it looks low, but the stick behind the seat says its full? Also there seams to be another nut about midway down the case that looks like an overflow kind of indicator? do I add fluid until it runs out of that overflow nut?
Sorry guys, Im just clueless......
Thanks for Help
   / How do you check Hydraulic Fluid in MF 255 #2
Thanks for Help
I have a 245 you sound like you are on the right path.
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
Toro z turn (A56859)
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A55315)
LIKE NEW 2023...
2024 WITZCO RG-52 LOW BOY (A57880)
2024 WITZCO RG-52...
