Need some info about Ram 2500 with the Cummins engine
   / Need some info about Ram 2500 with the Cummins engine #21
All SRW diesel '13 Ram trucks have 3.42 gears. You have to get a DRW truck to get 3.73 or 4.10 gears.
This is incorrect. You do not need a dually to have 3.73 or 4.10 gears on the new Ram diesels.
   / Need some info about Ram 2500 with the Cummins engine #22
Prove it.
Lots of guys got 3.42 trucks when they tried to order a 3.73 or 4.10 SRW truck. If you go to the build your own part on the Ram site it gives you the options for the other gears, but then tells you that you must also get DRW for those gears.
   / Need some info about Ram 2500 with the Cummins engine #23
Prove it.
Since what year
   / Need some info about Ram 2500 with the Cummins engine #25
2013 model year.
Oh ok cause I was gonna say not true for previous years. I don't know about 2013 but know now. Thanks
   / Need some info about Ram 2500 with the Cummins engine #26
The fuel economy reading is off due to the speedometer being calibrated for a larger tire than OEM. From 245/75 to a taller 285/70 brought my speedometer to true accuracy according to my GPS, and the economy meter went way down closer to reality.
   / Need some info about Ram 2500 with the Cummins engine #27
whos speedometer is off? the speedometer is calibrated for whatever gears and tires it leaves the factory with
   / Need some info about Ram 2500 with the Cummins engine #28
Not always. How many tire options? You think they reprogram the PCM for each one?
   / Need some info about Ram 2500 with the Cummins engine #29
   / Need some info about Ram 2500 with the Cummins engine #30
I simply don't believe that with my own speedometer reading 4-5 mph fast at 60 with OEM donuts. I've witnessed it on others as well.
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2025 JMR Tree Boom Skid Steer Attachment (A55851)
2025 JMR Tree Boom...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2017 Chevrolet Silverado Schwarze SuperVac Updraft Sweeper Truck (A55852)
2017 Chevrolet...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
