Trading up from a B9200 to L3200.
   / Trading up from a B9200 to L3200. #1
smoker
Central NYS
Kubota B9200
Any thoughts or suggestions? Had this 9200 since 1990 and it's really been a great machine. I think HST will be more user friendly as Arthritis has gotten a hold of hands and wrists. Would appreciate any input you all might have. Thanks, smoker
   / Trading up from a B9200 to L3200. #2
It would a be a nice step up for you. I would go with a L3800 since it has a live PTO. Before you buy it have the dealer put something heavy on the 3PH to make sure it is smooth. Some of these tractors have a jerky hitch. The HST is way more user friendly. Are you getting a loader? If you are you should get SSQA. Get the tractor equipped like you want it.
   / Trading up from a B9200 to L3200. #3
Quite a step up. Im sure you will enjoy the convenience and refinement of the L3200. Wish your B9200 was an HST version. Id be buying if you were selling. :confused3:
larry
   / Trading up from a B9200 to L3200. #4
Last year I went to a new L3200/HST/FEL R4's from a B7500/HST/FEL/R4's bought new in 2002. The difference was amazing. You'll love the beefier tractor. I had the dealer fill the rears and would recommend it. There were a couple places I used 4WD with the B7500 that the L3200 takes in stride in 2WD. One of my mowing patterns requires backing the tractor on a grade. With the B7500, I'd need to use 4WD or raise the RFM to get more weight on the back tires. The L3200 acts like there's no grade even if the grass is wet with dew.
Great info and encouragement....thank you. Loaded tires are a good idea, have them on my 9200 now. Again, thank you, Regards, smoker
   / Trading up from a B9200 to L3200. #6
Are you SURE it's worth parting with the B9200? Second tractors are REAL handy if you've got the space.
   / Trading up from a B9200 to L3200. #7
AND its got the 2 speed PTO; back, mid and front.
larry
Wish I was solvent enough to just keep the 9200, however......Never thought of advertising it as it's a PITA if you know what I mean. Just for discussion it has a FEL and a 5' belly mower all in very good condition.
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2021 New Holland C327 Compact Track Loader (A55218)
2021 New Holland...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
40' CONTAINER (A54757)
16FT Flatbed Truck Body (A52377)
16FT Flatbed Truck...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
