TIG gas lens parts question
   / TIG gas lens parts question #11
If you want to get real fancy you can get a CK torch with clear pyrex nozzles;)
Also makes a difference with aluminum and magnesium if you have much in the way of air currents in your shop.
I have to remember the "air currents" effect too. I do all my welding outside, on a concrete pad behind my house. It's the only place I have a 240v outlet, and it's the most fireproof place. I think it will probably be okay for TIG welding even though it's outside, because it's the exposed side of a daylight basement (used to be a garage, but was converted). The pad is surrounded on three sides by 10' high concrete walls, so there isn't much by way of wind in it. For TIG, I plan to stuff the welding table into a corner near the house, further reducing potential for breezes. But if I do run into any trouble maintaining coverage, a gas lens may help.
   / TIG gas lens parts question #13
I use to have one of them, tripped on the lead, jerked the torch, and magnet holder onto the ground and broke the cup! :censored::banghead::muttering:
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
KLEIN TOOLBOX (A50854)
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
