John deere off set disk
   / John deere off set disk #1
professor
Gold Member
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
Approximately how much hp will it take to pull an 8 foot heavy duty JD off set disk on rocky steep ground?
Can a NH 3930 4WD handle it?
Thanks
   / John deere off set disk #2
More than a 3930 would want. I would recommend you step down to a 6' disk for your tractor. Think you would wan't something you could pull in 4L or 1H.
You could pull it in most cases but not fast enough. Ideal would be a 75 to 85 hp tractor in a light to medium configuration approximately 7500 lbs.
   / John deere off set disk #3
I agree it might be a bit much for your tractor and terrain. With the steep slopes you may not want such an aggressive tillage tool anyway if you consider the soil erosion factor. Maybe a S-tine cultivator could get the job done without disrupting the soil structure so badly. These are fairly easy to pull and you could pull an 8 footer easily.
   / John deere off set disk #4
Exactly right.
   / John deere off set disk #5
Thanks
Could you post a pic of the disc? Ken Sweet
   / John deere off set disk #6
Your 3930 tested at ~45 hp (pto) and around 38 hp and 4800 lb pull (drawbar)--similar to my Mahindra 5525. I pull a 7 ft offset disc on flat level ground that has gravely loam soil. Don't know if you can get up enough speed on rocky steep ground.
Is that JD disc a wheel disc (mine isn't)? If so, you can always use the transport wheels to set the disc operating depth to compensate for lack of hp.
My neighbor has an 8 ft offset wheel disc that he pulls with his JD 2640 (~80 hp engine, 6500 lb drawbar pull). He uses it to till his 1/2 acre vegetable garden (mucho overkill but you use what you have).
Good luck.
1997 Equipment Trailer, Dual Tandem Axles (A52384)
1997 Equipment...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A53426)
2013 FREIGHTLINER...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53472)
2011 New Holland...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A51248)
UNUSED WOLVERINE...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
