Transmission problems of an Iseki TU 1900 4wd
   / Transmission problems of an Iseki TU 1900 4wd #1
Danielef
Ancona, Italy
Iseki TU1900 4WD
Few weeks ago after a major leak I found that the idler gear of the front wheel drive had "quit" the transmission. Referring to Figure 14 of section V-7 of the workshop manual: the idler literally broke the aluminum "input metal" (item 2, I prefer to call it "aluminum lid") that supports it, getting loose. I had the lid welded and the seat of the idler shaft re-machined in order to restore a true alignment, I reassembled everything and when the tractor started with no leaks or rattling I was very happy for having solved the problem. Unfortunately after few hours of running, the leak restarted because, obviously, a crack had reappeared.
I understand very well that the idler gear stands on a delicate equilibrium: its shaft is supported only on one side and the stress on the lid must be large but I don't see a good way to solve the problem.
I would be very grateful if someone has good suggestions. A new lid does not seem available but, as a last resort, I could have one machined.
Daniel
   / Transmission problems of an Iseki TU 1900 4wd #2
I may have a used one.
   / Transmission problems of an Iseki TU 1900 4wd #4
is the tu1900 the same as my tu 2100? because i have a hole in mine also. i bought mine that way with hopes of finding the metal input cover. not easy to find. what cause my broken one do you think?
   / Transmission problems of an Iseki TU 1900 4wd #5
I sent you an email with ordering instructions. The TU1900 & TU2100 are basically the same tractor with different injector pump settings.
Unused 2025 CFG MX15RX Mini Excavator (A50322)
Unused 2025 CFG...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2013 Ford F-550 4x4 Altec AT40M 40ft Bucket Truck (A50323)
2013 Ford F-550...
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
