Once again, synthetics and oil analysis
   / Once again, synthetics and oil analysis #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Numerous discussions on the benefits of synthetic oils and oil analysis.
My 2002 F350 7.3 is advised to change every 5K miles.
I switched to Rotella T-6 from quality dino oil last fall. Primarily for the "ease of starting when cold" which I had read about. Well that worked GREAT.
I also changed over my '88 Ford 7.3. Starting when cold issues about went away on the '88. On the 2002 it never even cranked slow ALL winter and I never plugged it in.
One oil change takes 15+ quarts, or about $82.50 at current walmart prices, plus $10 for a filter.
One oil analysis costs $19 plus postage, and tells me far more than if my oil is good for more miles.
Well, just got my oil analysis back from Blackstone.
GEORGE: You didn't put the time on the oil for this sample, but it looks like 6,922 miles were added to the
engine since the last report. Assuming that's how long this oil has been in use, everything still looks great.
Iron is a little higher, reflecting the slightly longer oil run, but metals are still reading at or below average
levels, and there are no signs of mechanical issues developing as far as we can see. The small amount of
fuel we found in the last report has gone away, and no other contaminants were found. This oil can definitely
go longer. Check back in ~3,000 miles.
So I'll check back in another 3K.
After I establish a pattern I expect I will be able to run it 10K miles between changes, just like I do my '09 Jetta TDI.
So $20 on an oil analysis saved me $80 on oil.
   / Once again, synthetics and oil analysis #2
How many miles on the 88? I have been thinking about switching over to syn on my 89, but it's got 255K+ (odometer has been broken) on it. I run Rotella 15-40 Dino in it now, any help in cold starting would be good for it!
Only about 190K.
   / Once again, synthetics and oil analysis #4
I run 11,000 between oil changes on my Jeep Liberty Diesel without bypass and such. No issues. I run my Detroit 12.7L to 25,000 with bypass with no problems. Considering moving that one up to 30,000 miles and see what the results are. Virtually all synthetics, regardless of brand, are good for a minimum of 7,000 miles and usually more. Since my Detroit takes 38 quarts per oil change and two Donaldson ELF3998 filters at $20 a pop, it makes sense to go further with the oil drains. I have been using the Delo 400 LE 5w40 synthetic from Wally World that has had a price of $19.98 a gallon since last fall.
   / Once again, synthetics and oil analysis #5
Have you had good results with the Delo?
   / Once again, synthetics and oil analysis #6
Copperhead : Have you had a analysis done on the oil in your 12.7 detroit ? Reason I asked , is what I found on my last truck was that although the synthetic was more stable in changing temp's , Soot levels were the same levels regardless at same miles as was metal wear , thus I gave up on synthetic oil's for engines . Still run in boxes , ( tranny and rear ends ) , but just run regular Rotella 15/40 in engine , Changed every 15,000 .
Blackstone Labs : Been with them a long time , Great analysis in that it is in layman's terms , You don't have to be a flippin' rocket scientist to read the dang thing .
Fred H.
   / Once again, synthetics and oil analysis #7
Fred H.
Yes, I run oil samples each time I change the oil. I primarily use Oil Analyzers, Inc for the mail in lab and also once in a while will have a sample run by Speedco to compare results with lab. I probably would balk at running synthetics in the Detroit if it were not that I can get the Delo 400LE 5w40 at a very good price. I am taking the oil 2/3 longer than OEM recommended drains, so the cost is lower overall and makes the choice a cost effective one.
   / Once again, synthetics and oil analysis #8
I have been changing the Amsoil in my vehicles about once a year @ about 12,000 miles. Been doing this for about 12 years now with great results. It is a waste of money to change any synthetic before 10,000 miles.
   / Once again, synthetics and oil analysis #9
Two gallons to do a change seems to be the breaking point for many or if the oil cost per change is 2x+ the cost of the test.
Delo 400LE 5w40 from what I read is very near to quality of synthetic and is what I would use vs Rotella Synthetic in an engine that took gallons to do an oil change. While I use it I think synthetic can be a little over hyped. :)
   / Once again, synthetics and oil analysis #10
I change my 2011 F250 6.7L diesel every 15,000 miles. I am thinking about trying a 20,000 mile interval soon. I use Amsoil premium synthetics along with an oil bypass filter. I use Blackstone for my oil samples. Their analysis is saying I could go with a farther interval between oil changes.
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A51247)
UNUSED CFG...
2016 RAM 3500 HD SERVICE BODY TRUCK (A53426)
2016 RAM 3500 HD...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
JOHN DEERE 1814E LOT NUMBER 257 (A53084)
JOHN DEERE 1814E...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
