RPM Gauge
   / RPM Gauge #1
BobsMassey
E.Aurora, NY
Massey Ferguson 1529
Hey guys anyone have a problem with the gauge for your RPM's pegging out at idol ?? Then after I have shut it down for like lunch, when I restart its back to normal !
   / RPM Gauge #2
Sounds like a bit of Carb cleaner to the cable input on the tach. Let it dry out. Then use some graphite. There is something like a centrifugal clutch within the gauge. It could be sticking.
   / RPM Gauge
Thanks, but the dealer said it was all electronic ??? The tractor is new I just got it in feb. and I was wondering if maybe something was dirty??? I'm gonna look if there is a cable !!!!
   / RPM Gauge #4
Assumed it was mechanical. Some electronic tachometers work for of Hall effect or magnetic reed switches. Could be the sensor has moved, poor connection or even failing. If your thinking dirty. Possible if it's a photo reflective sensor. Laser portable tachs work that way. You can goto www.agcopartsbook.com and lookup your model and look for the sensor. It can be a real PITA having to take the tractor in for a minor problem especially if it's quite a drive away and limited means to transport. Maybe you can speak with a tech on the phone to give you an idea as to it's location. Good luck.
   / RPM Gauge
Assumed it was mechanical. Some electronic tachometers work for of Hall effect or magnetic reed switches. Could be the sensor has moved, poor connection or even failing. If your thinking dirty. Possible if it's a photo reflective sensor. Laser portable tachs work that way. You can goto AGCO Parts Books and lookup your model and look for the sensor. It can be a real PITA having to take the tractor in for a minor problem especially if it's quite a drive away and limited means to transport. Maybe you can speak with a tech on the phone to give you an idea as to it's location. Good luck.
thanks !! It is under warranty and the last time I needed something small they came out and fixed it on site, I just don't want a major problem to happen from this !!
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2026 Hillcrest Dump Trailer (A56858)
2026 Hillcrest...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
19010 (A55851)
19010 (A55851)
