How do you clean your wood deck??
   / How do you clean your wood deck?? #11
Im with jinman. I use bleach. Its cheap and works extremly well and quick. It will burn nearby vegatation a lil but those plants will quickly recover.
   / How do you clean your wood deck?? #12
Tide with bleach, wet the deck, sprinkle it on, then brush across the grain to try to keep from pulling the soft grain out of the wood. Wash all off with a garden hose with a spray nozzle.
   / How do you clean your wood deck?? #13
If you are worried about plants, cover them with cheap painter's plastic. The plastic works great for furniture or anything you don't want splattered. I think Pete Judd's solution might be the best of all. A little added detergent ( with phosphates) will make your grass happy and a garden hose will rinse off the deck without sending splatter into the ionosphere.;)
I actually bought a box of Tide and some liquid bleach last fall but never got around to trying it. Appreciate all the good suggestions and will probably start with the detergent/bleach approach and test on a section.
What proportions of bleach/Tide/water do you use? Also, not sure what you mean by >>... to keep from pulling the soft grain out of the wood<< ?
2018 CATERPILLAR 415F2 IL SKIP LOADER (A52705)
2018 CATERPILLAR...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55301)
GALAXY - SET OF...
201930 (A54756)
201930 (A54756)
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
black Max power washer (A55787)
black Max power...
