Woods GTC60 roto tiller removal of broken shaft
   / Woods GTC60 roto tiller removal of broken shaft #1
dfreetly
Hi all,
I have a 2004 Woods GTC60 roto tiller that I believe has a broken shaft. My question is.....how do I get the shaft out of the housing that runs to the gear box? I have it disassembled but I can't figure out what to do next. Maybe I need to buy the shaft and housing with bearings all in one?
Thanks for any advice.
Dave
   / Woods GTC60 roto tiller removal of broken shaft #2
GTC60 Rotary Tiller
From this parts page, it looks like there is a snap ring that holds it in place. Click on the Gearbox section.
Hope this helps.:)
GTC60 Rotary Tiller
Hope this helps.:)
Thanks beckmurph but I already had removed the snap ring and that didn't let me take the shaft out. Any other suggestions?
   / Woods GTC60 roto tiller removal of broken shaft #4
If you look at the blowup of the parts, there is a shaft listed, but no shaft housing.
Are the shaft and housing considered one piece?:confused3:
I'm looking at the parts diagram and it looks like the bearings come off the shaft. Any idea how I can get the bearings off? Maybe that will give me a clue about the shaft and housing being all one unit or separate parts.
   / Woods GTC60 roto tiller removal of broken shaft #6
It looks like you need to support the housing, then knock the shaft out. Then remove the bearings on each end.
Thanks Don....I'll give it a try.
   / Woods GTC60 roto tiller removal of broken shaft #8
Use a block of wood, so you don't bugger up the end of the shaft.
I was able to get the shaft out of the housing and as I expected it was in 2 pieces. Surprised that a shaft that thick would break.IMG_1150.jpgIMG_1151.jpgIMG_1152.jpgIMG_1153.jpg
Lockwood 480 Pecan Harvester (A53473)
Lockwood 480 Pecan...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53473)
2015 Ford F550...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
40ft Shipping Container (A52377)
40ft Shipping...
UNUSED (2) 30PCS Grey Metal Roof Panels (A53117)
UNUSED (2) 30PCS...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
