4 wheel drive operation x700 series
   / 4 wheel drive operation x700 series #11
Thanks much for checking that out,that settles it.The way they set this up,the front axle reacts exactly like a shaft driven front axle.Could be the way they designed the front axle.It must have some sort of differential in the center with the separate wheel motors driving each axle.With no over running clutches in the hubs and the hydraulic input to each motor at rest,the front wheels would fight each other,providing resistance travel in either direction,just like any open carrier differential with restrained driveshaft movement.Kudo's to JD for building a powerful and safe machine for hill work.
   / 4 wheel drive operation x700 series #12
Best I can tell Tuff Torq offers three different fwd axles that are hydraulcally powered from the various rear axles. Comparing your picture with these might ascertain what you have. Your picture first, then KHXN 7, 10 and 13, the x749 is using the KHXN13 model best I can tell. More information available at Tuff Torq site with larger pictures in pdf printer friendly form.
   / 4 wheel drive operation x700 series #13
It's a 10 series.Sent an enquiry to Tuff Torq as to the operational characteristics of the different models.
Caterpillar 725 Off-Road Dump Truck (A57453)
Caterpillar 725...
New/Unused CFG Industrial NT18K Mini Excavator (A57453)
New/Unused CFG...
40' High Cube Multi-Door Container (A57149)
40' High Cube...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
2018 Ford F-350 Crew Cab Service Truck (A56858)
2018 Ford F-350...
