stuck fuel filter jinma 354
   / stuck fuel filter jinma 354 #1
gergstuff
Ferndale, WA
Jinma 354
I was trying to replace the fuel filter on my recently aquired jinma 354. I cannot get it to budge. The mount the spin on housing is attached to is bending. I suspect it is rusted on there as the tractor has been sitting outside with little use for 6 years.
Any ideas on how to get it off withoutbreaking something would be appreciated!
Craig
   / stuck fuel filter jinma 354 #2
I had that problem also at my first filter change. Had to remove the filter and head assembly from the tractor and put it in a vice and use a chain wrench. The filters don't have to be that tight. When you reinstall it put a film of lube oil on the seal surface where it contacts the filter head.
   / stuck fuel filter jinma 354 #3
Given the presence of engine oil, I doubt it's rust. The more common problem with these is paint. Rather than paint the block before assembly, they spray the whole **** thing as it goes out the door. I got mine off by driving a screwdriver through the filter canister then putting a cheater pipe on the screwdriver handle. You'll likely have to do the same thing with the fuel filter.
//greg//
   / stuck fuel filter jinma 354 #4
Craig
I had the same problem with my 304, and I removed the entire housing and took it to my vise, and then I got right aggressive with it.
   / stuck fuel filter jinma 354 #5
Same here for me, Mine (JM284) was right at the point of bending my bracket which is started a bit. I stopped took a small rubber hammer and tapped the (;@p out of it. I put filter wrench back on and still started to bend a bit. At that point I used ball peen hammer and a round bar to ding the top edge some. still would not come loose so I got a dull flat chisel and hammered the top edge about 1/3 way around in a knock it loos direction which got it off. It did break the filter and spilled fuel in the process the thing came off though...
Mark
   / stuck fuel filter jinma 354 #6
uuuh, is the filter a spin-on, or is it held in place by a small bolt down thru the top of the bracket?
   / stuck fuel filter jinma 354 #7
I had trouble, Ron, and mine was a spin on. There is a bleed bolt at the top, but it is only a spin on filter on mine.
   / stuck fuel filter jinma 354 #9
For the spin on's a long screwdriver, a smaller chisel and a good hammer f
Should do the job.:thumbsup:
Course if there is room a long handle will Work wonders. :D
2006 INTERNATIONAL 9400I SLEEPER (A53843)
2006 INTERNATIONAL...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2003 Pierce 75ft Ladder Fire Rescue Truck (A51692)
2003 Pierce 75ft...
2013 Ford F-250 Pickup Truck (A51692)
2013 Ford F-250...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
