12V boomless 20-50 gallon sprayer?
   / 12V boomless 20-50 gallon sprayer? #1
XSKIER
Fenton, MI
'11 Deere 1026R
I'm looking for a small sprayer to fit my 1026R that will allow me to apply "crossbow" in and around trees and ditches. An area of about two acres. The sprayer would also need a gun for spot spraying. Any reviews or recommendations?
   / 12V boomless 20-50 gallon sprayer? #2
We offer 3pt PTO Driven Sprayers from 25 gallon up to 200 gallon. We do offer a boomless nozzle option for the same price. The sprayers come complete with a 6 roller Hypro pump, 25'hose/pistol grip handgun for spot spraying as well as your choice of a 12' folding boom or boomless nozzle. If it's going on a tractor with a pto like yours, i'd prefer pto driven over 12V.
Our sprayers ship free to a business or supporting freight terminal within 1,000 miles of Newton, NC.
That certainly is an impressive sprayer.
The more I thought about it, I don't really need broadcast spray ability because the poison ivy I'm trying to knock out is not growing in the wide open areas, the largest of about 5000sf. I looked at a handful of 4 gallon back pack sprayers yesterday, and was pretty sure I wanted one until I tried out the Stihl SG 20. Too much hand pumping required and not much spray distance. I decided to go to TSC and buy the "countyline" deluxe ATV spot sprayer and a receiver hitch cargo carrier to set it on. Luckily, my local store had ordered in a fimco 3pt 40 gal with 7' folding boom for somebody, but then got stuck with it. As I looked at it unassembled in the box, the pieces appeared to be of satisfactory quality, and I've known TSC to be an understanding company should satisfaction issues arise after using the item. As I assembled the sprayer, I thought what a well thought out design and great attention to detail. All of the hardware and fittings exude quality, which is rare in a value priced implement. The frame is held together with 18 5/16" grade 5 plated flange bolts with locking flange nuts. The tank is bolted on as well as strapped down. The pump is 2.1 gpm at 60 psi, which is just adequate enough to spot spray at 30 psi while returning a little back to the tank for agitation. I've run about 60 gallons through it with good results and will update as more use allows.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
2007 FREIGHTLINER M2 BOX TRUCK (A53426)
2007 FREIGHTLINER...
