Can you blend synthetic and "real" oil
   / Can you blend synthetic and "real" oil #1
pjbci
Summit. Ms
JD 4840, Deere 5075e, 450j, Cat D4k2, Kobelco 160, Volvo EC140el, deere 310, komatsu D31px22, IH 1486, MF 135, MHF TO35
A year ago i bought a new komatsu dozer that burned engine oil from day one. 3 months ago komatsu put a complete new engine in because of the oil consumption. Said it was a manufacturing defect. Anyway, the new engine is burning oil also so i had the dealer bring some oil out when he came to pull an oil sample. He brought phillips 66 synthetic 15w40. The motor has komatsu "dino" oil in it. Whats yalls opinion, do i top it off with syn or make the 20 mile trip to dealer for the correct oil?
   / Can you blend synthetic and "real" oil #2
Top it off. Modern synthetics are able to mix with conventional oils without issue with very few exceptions.
Thats what i wanted to hear. Thanks.
   / Can you blend synthetic and "real" oil #4
Best to wait to add synthetic until after break-in period has passed; but since the new engine seems to be using oil already it probably won't make a difference.
   / Can you blend synthetic and "real" oil #5
My truck came with synthetic from the factory.
   / Can you blend synthetic and "real" oil #6
Yeah, the old "break it in on dino to seat rings,bearings,etc" is an old wives tale. Many new and very expensive vehicles come from the builders with synthetic oil
   / Can you blend synthetic and "real" oil #7
i agree.. i'd have no qualms topping off with dino.
if i was doing a full oil change i wouldn't mix.. just because. however it should not hurt.
look at the semi-blended syn's today. just dino and some syn mix anyway..
Thanks guys. I topped it off this morning.
   / Can you blend synthetic and "real" oil #9
I did not say it could not be done. Here we're dealing with an engine owner who says his new replacement engine is burning oil like his original engine did from day one. Both of these engines came from the factory with dino oil, NOT synthetic. Synthetic from the factory on high end engines or run of the mill new trucks is the manufacturer's choice. Some do, some don't. The question is about mixing oils on the second engine that seems to be having oil related consumption issues. It has dino oil. Adding syn to the dino isn't likely to change anything, in fact it might improve, i.e. reduce oil consumption over time, but that's another discussion.
I don't recall where I read it, but the thinking was if an engine had dino oil in it from the factory to wait until after the first oil change to switch to synthetic. That can't be a bad thing, and where one chooses to add synthetic to a brand new engine before the first oil and filter change is due is probably not earthshattering either, in the long run.
Amsoil, as but one example, does state in their FAQ section that mixing syn with dino does reduce the extended interval oil change otherwise used when using ONLY synthetic.
Note that the OP has not described what he means in any quantitative way, by burning oil in either engine's case.
That info would be helpful in determining what it is he is really dealing with regarding these two engines. I doubt the manufacturer would agree to swap out engines without a serious issue behind that choice. More info from the OP would be useful....
And several years ago a few synthetic oils were and still are today blends, as others have mentioned. So the final answer as to what works best for all situations/engines is, IMHO, still out.
   / Can you blend synthetic and "real" oil #10
Did you mean:topping off with synthetic?
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
greenworks (A53421)
greenworks (A53421)
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
