How do you edit the title of a post
   / How do you edit the title of a post #1
navyjoe
Eastern Tenn
Kubota BX2380 and L2501
The title of one of my post is wrong. I can't find a way to correct it. Is it possible to fix one?
   / How do you edit the title of a post #3
You can't, but you can delete the post for a certain time period.
Just rewrite the post correctly.
   / How do you edit the title of a post #4
You can change the title in a reply It won't change the OP title though...use the "advanced" interface...
Thanks for the input fellas.
So if I understand your replys short of deleting the whole post it can't be done. I hate to delete the post because it has a lot of good info, but the title no longer matches the content!
I guess I need to investigate copying it over to a new post then deleting the old post.
   / How do you edit the title of a post #6
Cut & paste the info from the old post into the new one :)
Thanks, sounds like a plan!
Have you been impacted by the fires in Co?
MAGNUM PRODUCTS LIGHT TOWER (A50854)
MAGNUM PRODUCTS...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2017 PETERBILT 587 TANDEM AXLE SLEEPER TRUCK (A51222)
2017 PETERBILT 587...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
