Need help location ring and pinion for a NAA
   / Need help location ring and pinion for a NAA #11
Sorry I did not see that.
What good is just a pinion? They really should come together.
There was a thread where some guy was looking for parts and everybody listed a bunch of salvage yards. I'll see if I can find it.
   / Need help location ring and pinion for a NAA #12
in a car or truck.. it's a must to get a matched set. on tractors.. not so much. nic IF you could find it.. but I know plenty of palces that sell singally.
   / Need help location ring and pinion for a NAA #13
Ungertractor.com has a NAA listed that they are parting out.
   / Need help location ring and pinion for a NAA #14
FYI- at approximately serial number 44000 on the Jubilee, the ring gear and pinion pressure angle was changed from 20 degrees to 25 degrees. You must have ring and pinion with matching pressure angle. As Soundguy says, replacing either ring gear or pinion individually on a tractor is acceptable but pressure angle of the replacement must match the the part your using it with. This information is somewhat obscure with even a few of the so called experts were unaware. Folks installing a pressure angle mismatch has likely contributed to the myth you can't replace one without the other. If you need the exact serial number break, I can look it up.
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2011 GALYEAN 130BBL VACUUM TRAILER (A53843)
2011 GALYEAN...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
