Hinged Box Blade vs. Fixed edge Box Blade
   / Hinged Box Blade vs. Fixed edge Box Blade #1
CTMassey
Massey-Ferguson 1529
Just thought i'd get some thoughts on this. if I have the opportunity to find a used one theyre usually a fixed cutting edge. I'll mostly be doing medium duty repairs to driveway and access to woods for firewood....
   / Hinged Box Blade vs. Fixed edge Box Blade #2
I have both and both work well, the ones with hinged blades are usually heavier duty and more expensive. I got by many, many years with a standard box blade without hinged plate and manually adjusted scarifiers. I prefer the hinged blade, but a good heavy scraper properly sized to your tractor should fit you needs quite well with or without the hinged blade.
A search will bring up a lot of useful old threads on this subject.
I find a hydraulic top link helps a lot with a box scraper.
   / Hinged Box Blade vs. Fixed edge Box Blade #3
I prefer the fixed back blade, not the hinged. That way, I can tilt the bb up enough in front to ride on the rear blade for "only hitting the high spots".
   / Hinged Box Blade vs. Fixed edge Box Blade #4
The thing I like about mine is that I can bolt the rear blade in place so I can use it either way.
   / Hinged Box Blade vs. Fixed edge Box Blade #5
Yep Larry, mine's like yours. If I'm doing rough work I like it hinged. Allows the front cutter to take a bigger bite. If I'm doing delicate finish work like leveling gravel I like the rear blade bolted solid, lots better control. Also as Ken states, having the ability to tilt the BB with a hydraulic top link makes a world of difference as well.
Larry and I are grossly spoiled, our BBs also have hydraulic operated scarifiers. With Top n Tilt added you can do almost anything with it without getting off the tractor.
   / Hinged Box Blade vs. Fixed edge Box Blade #6
Expensive, but one the very best investments I ever made as we do quite a bit of dirt work.
   / Hinged Box Blade vs. Fixed edge Box Blade #7
A fixed rear blade makes it hard to cut on on a ground transition where the blade is in an "upward" position in relation to the tractor, like going down the bottom part of a hillside. No matter how short the top link is, the front blade won't cut.
Bruce
   / Hinged Box Blade vs. Fixed edge Box Blade #8
I prefer a rollover blade to either of the standard boxes and I have used all three over the years. You can flip it backwards for dragging out the high spots on the drive and the increased weight helps as well. Plus, you can use the scarifiers independently of the scraper which allows digger digging and smoothing without the hassle of removing them. More money, but over time it is insignificant.
   / Hinged Box Blade vs. Fixed edge Box Blade #9
Yeah that is a whole different thing and there are lots of threads on them, for those not familiar here is just one. I knew little about them before other members were kind enough to explain them. I really like my HR3584 for use with a cab tractor, but can see where some people like the rollover.
http://www.tractorbynet.com/forums/attachments/98520-gannon-rollover-box-blade-scraper.html
   / Hinged Box Blade vs. Fixed edge Box Blade #10
Like Larry and Richard, I also have a heavy duty box blade with hinged rear blade, that can be bolted into place when needed/wanted. The hydraulic scarifiers and Top N Tilit cylinders are my favorite aspects to the box blade, moreso than the hinged blade, it definitely spoils you. :thumbsup:
I've never bolted my hinged blade in the fixed position, I've never felt the need, but I will try it someday just to see the difference. Personally I like having the option.
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2012 TROXELL COMPANY 130BBL VACUUM TRAILER (A53843)
2012 TROXELL...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A53473)
Koyker Loader...
