Small hole in oil pan fix? To braze or not to braze?
   / Small hole in oil pan fix? To braze or not to braze? #31
Are these fuel tank sealers rated for the heat that an oil pan will see? Fuel tanks generally don't get too warm.
I found a different type of patch material. Supposed to stand up to heat as well as oil and gas. I don't have it in front of me right now. It only needs to last a few weeks until I can get it back over to the main farm.
   / Small hole in oil pan fix? To braze or not to braze? #33
Depending on how new your tractor is... A good wire brushing, and the hole could get 10 times as big. Although, being a new scrape, perhaps that won't be an issue.
   / Small hole in oil pan fix? To braze or not to braze? #34
most epoxies are good to about 400' witht he specialy intake type for over 2x that. if it's a low corner oil pan hole. regualr epoxy should last himthe couple weeks he needs.
UNUSED 72" HYD ROCK GRAPPLE BUCKET (A54757)
UNUSED 72" HYD...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
Kubota K7874 18in. Bucket (A52377)
Kubota K7874 18in...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
